3500 dully plastic fender crack in cold temprature
Old 01-23-2011, 10:15 PM
rich414's Avatar
Default 3500 dully plastic fender crack in cold temprature
I have a 2004 3500hd dully, I live in a COLD climate and I am on my 2nd set of rear fenders or quarter panels.
We have had temperatures in the ZEROS over the last month and a few cracks have appeared in the lower section of the rear panels. Not sure how the cracks happen, in one area of the panel, I backed into a snow pile and the fender just shattered. I have the pieces. I am not alone in this, all the 3500 in my town have busted, crack missing sections of rear fenders. I just want to fix the cracks and put the pieces back
I have drilled each end of the cracks and the cracks have stopped running.
When I disposed of the first set of fenders, I kept a piece of the fender to test repair techniques. Yesterday I found the test piece of fender in the garage which is about 60 degrees, and I tried to bust the piece so that I could fiberglass it back together. I could not break the piece, it just bent. I set the test piece outside for a few hours, the temp was 20 degrees and I had no problem snapping a section off.
So I sanded the back sides of both section, taped the section together on the front, with a 1/16" gap and fiberglassed the pieces together with 2 layers of cloth... Today, I gave the repair a test and I was able to separate the repair into to 2 pieces without much effort, the failure occurred at the fiberglass plastic bond.
So there is my story. Fiberglass is not the repair solution.
How do I fix the fenders?
What is the plastic compound that the fenders are made from?
The wife said that a flatbed is NOT an option...
Thanks
Old 01-29-2011, 07:25 PM
rich414's Avatar
to the top....
In2Trux
GM How-To's and Tutorials
05-31-2014 09:18 PM
mcboo_Sierra
02-25-2011 03:08 PM
dziedzic07
02-22-2007 06:02 AM
73ford
02-10-2007 10:02 PM
bluez
06-06-2006 03:25 PM
Quick Reply: 3500 dully plastic fender crack in cold temprature
