Power windows
Old Feb 27, 2018 | 11:29 AM
Schatzzy78's Avatar
Unhappy Power windows
I HAVE 2000 gmc sierra 1500 reg cab 5.3 truck i have window problems
ok so i replaced the regulator and switch but the problem still drivers window wont work i tested the motor and tested for power i have power but i have power to motor when switch is not activated pass works fine thought maybe a relay but have no idea where it is so cant check that the breaker is fine the wire harness looks fine but thinking some one moved wires in plug but cant find a good diagram to check this if i unplug switch power goes away but it brand new switch and old one did the same i tore old one apart nothing is burnt i am totally lost was gonna get a new harness but not sure if that is the problem any other questions ask i tried to explain best way i could and next thing i cant change my climate control the fan works but stuck on vent and cant change heat to cold any ideas i didn't start diagnosing this yet thank you and will post back if any of your suggestions work or if i find problem thank you again
Old Mar 4, 2018 | 01:54 AM
Schatzzy78's Avatar
Hey guys any ideas is there a relay I missing. I think a relay stuck would cos some of my issue where would I find the relay Did I stump you guys on this. It really got me baffled thanks guys for any help
Old Apr 1, 2018 | 11:34 AM
winright007's Avatar
I had a drivers side window problem a while back. Thought it was the motor, but turns out it was the cable system used to lower and raise the window. Check your cable system where it goes into the motor, mines was almost broken and finally did.
Old Apr 2, 2018 | 07:33 PM
Schatzzy78's Avatar
replaced whole thing. Can’t get the switch to stop sending power to window and can’t find any good diagrams for the wiring
mgrable
Mar 15, 2008 12:58 PM
jpgoodnu
Dec 19, 2007 06:46 PM
wareagle
Aug 13, 2007 07:15 AM
GMAN
Aug 16, 2005 01:27 AM
GMAN
Jul 18, 2005 10:28 PM
