Problem with new injector on 89 2500w/5.7
Old May 16, 2010 | 05:54 PM
westoverc1's Avatar
Default Problem with new injector on 89 2500w/5.7
HI there,
I just got my truck back from a crappy shop and they told me I had a bad injector (Drivers side). I drove the truck home and it ran but would barely go over 25 Mph. Anyway, got it home, put in new injector and tried to start it and there is so much fuel in the exhaust pipe it actually caught fire! Luckily, I had an extinguisher handy and put it out. Anyway, I let it sit for a while thinking I could let some of the fuel evaporate but when I gave it another try, you can see the fuel dripping out where the manifold meets the Y pipe. Is there something I need to check or is it just so flooded with fuel that it's going to have to sit for a while? I took the plugs out on the passenger side (where it's happening) to try and help it evaporate but I'm still getting fuel buildup in the pipe.
Anybody's help would be huge. I use this truck for work and need to get it running tonight!
Thanks!
Old May 16, 2010 | 07:59 PM
Could they have given you a 454 injector?
Old May 16, 2010 | 09:59 PM
westoverc1's Avatar
I don't know. The one they gave me doesn't have a torx head on it. The one that's in the truck does.
Old May 17, 2010 | 06:44 AM
Do you have the part number?
Old May 17, 2010 | 09:16 AM
RUFFNECK4LYFE's Avatar
You should check the valve springs on that side. A busted spring will cause it to run rough and throw a misfire code.
slicedpi
Apr 15, 2015 09:38 AM
adampgasser
May 12, 2008 08:11 PM
sootjunkie65
Jul 4, 2007 11:31 PM
rado2k
Apr 27, 2006 12:15 AM
specht
Nov 25, 2004 01:16 AM
