rear brake pads
Old May 11, 2011 | 07:51 AM
illgotoo's Avatar
Default rear brake pads
I'm replacing the rear brake pads on a 2004 2500 HD diesel. I have pulled off the calipers and the pistons are pushed back. The pads don't come out easily. How do the pads come out?
The pads are slotted and slide along a plate. I thought I could angle them out, but no.
There are two pins with dustcovers that the two halves of the caliper slides along. Do I have to remove these pins to get the pads off?
Old May 11, 2011 | 11:05 AM
glterpening's Avatar
I recently worked on the rear brakes on my 2003 1500. This was the thread:
https://www.truckforums.com/forum/ch...o-early-16307/
What I found was that it is better to remove the caliper holder (mine had two 18mm bolts holding it on) and take the stuff to a workbench. My pads were stuck, also. It took some time to clean things up.
Maine-iacs
Aug 9, 2009 12:52 AM
99rdking
Dec 26, 2008 11:35 AM
RobF1970
8
Aug 8, 2007 10:27 AM
nuukem
Jul 14, 2007 05:04 PM
texjm1
Apr 3, 2007 08:57 PM
