-   -   rear differential and axle (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/rear-differential-axle-5035/)
jensn04@aol.com Nov 4, 2007 10:25 AM
I have a 00' 2500, I just had the rear spider gears replaced due to wear, then the drivers side axle bearings, I then took it back to the drive train specialist, due to more noise out of the rear end. I was advised that there maybe a flat spot on the axle, is causing thenoise. I was also told that I should be able todrive it without any problems, but I will have to livewitht he noise or a new axle. Any ideas from anyone? The truck only has 60k miles on it, with a gas 6.0, it has been used to pull a 5th wheel horse trailer and travel trailer. Thanks
Argon Nov 5, 2007 04:13 AM
RE: rear differential and axle
HUH?..how is an axle gonna get a flat spot??>..find another tech...he's either trying to hose ya,or just an idiot
Cracker Nov 5, 2007 10:37 AM
If the bearing was bad could it potentially wear a spot in the axle......or no?
Tweaker Nov 5, 2007 12:55 PM
I did my rear myself I changed the spider gears, carrier bearings, and the axel bearings + seals to get a full rebuild. Meh imo it sounds like he didnt set your Pinion gear backlash right which I bet Argon wouldnt think I would be too off on that one cause a flat spot in the axel with only worn spider gears is strange (though only imo). o.O
Argon Nov 5, 2007 01:52 PM
the axles goes round n round..it ain't gonna get flat...it will wear down a pitted groove if the bearing is bad
