rear differential and axle
Old Nov 4, 2007 | 10:25 AM
jensn04@aol.com's Avatar
Default rear differential and axle
I have a 00' 2500, I just had the rear spider gears replaced due to wear, then the drivers side axle bearings, I then took it back to the drive train specialist, due to more noise out of the rear end. I was advised that there maybe a flat spot on the axle, is causing thenoise. I was also told that I should be able todrive it without any problems, but I will have to livewitht he noise or a new axle. Any ideas from anyone? The truck only has 60k miles on it, with a gas 6.0, it has been used to pull a 5th wheel horse trailer and travel trailer. Thanks
Old Nov 5, 2007 | 04:13 AM
Argon's Avatar
Default RE: rear differential and axle
HUH?..how is an axle gonna get a flat spot??>..find another tech...he's either trying to hose ya,or just an idiot
Old Nov 5, 2007 | 10:37 AM
Cracker's Avatar
If the bearing was bad could it potentially wear a spot in the axle......or no?
Old Nov 5, 2007 | 12:55 PM
Tweaker's Avatar
I did my rear myself I changed the spider gears, carrier bearings, and the axel bearings + seals to get a full rebuild. Meh imo it sounds like he didnt set your Pinion gear backlash right which I bet Argon wouldnt think I would be too off on that one cause a flat spot in the axel with only worn spider gears is strange (though only imo). o.O
Old Nov 5, 2007 | 01:52 PM
Argon's Avatar
the axles goes round n round..it ain't gonna get flat...it will wear down a pitted groove if the bearing is bad
Mox
8
Jan 27, 2011 09:53 PM
tmoulin
Nov 2, 2009 06:32 AM
joey316g
Dec 10, 2007 11:41 AM
jensn04@aol.com
Nov 4, 2007 08:08 AM
Hilly1999
9
Aug 9, 2007 01:16 PM
