removing door panels
Old Sep 25, 2009 | 12:43 AM
KC03silverado's Avatar
Default removing door panels
I have an 03 silverado, I had some speakers put in to replace the stock. But my warranty expired on the installation and I bought an amp for the speakers. But now, how in the hell do I remove the panels? I removed many before on older models I tried using my panel remover tool but seems like I can not find any clips. So I took the screws out 1. by the door handle, and 2nd. on the underside of door panel that goes into the cubbie hole .
Old Sep 25, 2009 | 03:35 PM
Don't pry on it. Basically you need to take out the screw that is visible by the door handle, remove the door lock/window switches by just pulling up on the entire assembly and unplug everything, remove the screw behind there, remove the plastic trangular shaped panel that is directly behind the side view mirrors by pulling straight out, remove the plastic trim around the door handle by pulling straight out, and then take a hold of the grab handle and pull straight up. Before you go walking away with the panel you will need to unplug the tweeter and the light that is on the bottom of the door. Now it is free, free at last!
Old Sep 25, 2009 | 05:51 PM
acnas's Avatar
Watch out for window switch. 03 they put a bolt in the underside of the switch so it doesn't just pull up. Switch stays in the panel. You have to disconnect the connectors from the switch. It is easier to disconnect the connectors after the panel is loose from the door so you can spin the door panel to access.
Old Sep 25, 2009 | 08:29 PM
Thanks for the update my truck is a 2002 and I assumed they were the same.
Old Sep 26, 2009 | 01:15 AM
thanks for the info. I greatly appreciated
Old May 6, 2010 | 03:47 AM
crazydrive's Avatar
So would it work to sub a one touch window switch with the sunroof switch to make it one touch?
dannys1
GM How-To's and Tutorials
Apr 2, 2011 03:38 PM
GeorgeO8
Jun 28, 2010 09:18 PM
Jim Rodman
Feb 10, 2010 08:38 AM
rdowner22
12
Aug 4, 2009 06:53 PM
rak187
Jul 10, 2007 12:14 PM
