replacing automatic transmission lines 2005 GMC
Old Jan 14, 2014 | 09:24 AM
Bruce's Avatar
Default replacing automatic transmission lines 2005 GMC
Anyone do this? I have a 2005 GMC Sierra four door 1/2 ton, and the lines are starting to drip. I would like to replace them myself. But I cant find any info on it. Any help, tips would be apreciated. Thanks Bruce
Old Jan 14, 2014 | 04:33 PM
Are you buying pre molded lines (OEM) ? Or fabricating up your own new lines?
Old Jan 15, 2014 | 05:41 AM
Bruce's Avatar
I will be getting them from the local GMC dealer.
Old Jan 15, 2014 | 09:22 AM
Great idea getting OEM lines. I highly recommend replacing the lines one at a time. This will avoid crossing the connection points.
Some lines will have different size fittings to avoid this mistake.
Old Jan 16, 2014 | 05:49 AM
Bruce's Avatar
In2trux, Have you done this? Is there any tips you can give me for this job? Thanks Bruce
Old Jan 16, 2014 | 10:05 AM
I've never replaced BOTH the lines... I only ever had to place one.
It's a tight place to work but you can do it.
Disconnect one line at the tranni then disconnect the same line at the rad.
The lines may have clips attaching them to each other. Remove those.
Start pulling the line back.
When you go to put your new line.. wrap the leading end in tape so as not to damage the tip of the line and to prevent dirt from getting in the line.
Repeat this for the second tranni cooling line.
After topping up your tranni fluid. Keep checking your tranni fluid level a few times to insure all the air has escaped.
Let us know how it went.
jackscars
Nov 12, 2010 10:33 AM
Melium
Nov 8, 2010 06:13 PM
kortmeyer
Jan 17, 2010 03:18 PM
mjn030
Jul 21, 2009 08:48 AM
f16z28
Oct 25, 2008 09:51 AM
