Running a CB wire, need help!
Hey yall, ive got an 01' extended cab z71 silverado and i just mounted a new CB antenna on the top of my bed right behind the passenger area. I ran the wire through the side of the bed where there was already a hole. Now ive got the wire downunder the cab and i cant find an area to run it up into the cab... Any places yall know of where i can find a hidden gromet or something? any ideas would be great... thanks!
RE: Running a CB wire, need help!
you could always run it up tp the engine compartment and go in from there near where the wiring harness goes in. There are usually grommets there that you can trim and then reseal.
there's two holes on the back wall of the cab you can get to if you get under the truck, that's where i ran my coax in through... they're about halfway up the back wall, one on the driver side, one on the passenger side...
You'll see them if you remove your backseat.
