Running a CB wire, need help!
Old Jun 15, 2007 | 06:26 PM
chevyman18's Avatar
Default Running a CB wire, need help!
Hey yall, ive got an 01' extended cab z71 silverado and i just mounted a new CB antenna on the top of my bed right behind the passenger area. I ran the wire through the side of the bed where there was already a hole. Now ive got the wire downunder the cab and i cant find an area to run it up into the cab... Any places yall know of where i can find a hidden gromet or something? any ideas would be great... thanks!
Old Jun 15, 2007 | 06:43 PM
smoke20's Avatar
Default RE: Running a CB wire, need help!
you could always run it up tp the engine compartment and go in from there near where the wiring harness goes in. There are usually grommets there that you can trim and then reseal.
Old Jun 16, 2007 | 12:11 PM
chevy112488's Avatar
there's two holes on the back wall of the cab you can get to if you get under the truck, that's where i ran my coax in through... they're about halfway up the back wall, one on the driver side, one on the passenger side...
Old Jun 16, 2007 | 03:14 PM
MrLM7's Avatar
You'll see them if you remove your backseat.
eviltouch89
14
Jan 6, 2014 09:16 AM
cubpak89
Aug 6, 2011 04:25 PM
quint2
Mar 5, 2009 05:10 AM
chevyfreak36
Jun 8, 2006 02:40 AM
gruusome
May 24, 2006 12:55 AM
