Safest way to jack truck...
Old May 10, 2019 | 05:01 PM
KennyB's Avatar
Default Safest way to jack truck...
GMC Sierra 1500 SLT 5.3L
Where is the best place to jack the truck if you wanted all 4 tires off the ground at once?
Seem’s to be allot of different opinion’s and will probably get allot more but:
Is it safe to jack on the front cross member to lift both front tires at the same time?
When doing this where should the jackstands be placed, Under the frame?
For the rear end under the differential?
If you jacked on the frame is it safe to jack one side up, place jack stands then do the other?
Seems this may be hard on the frame.
BirdDooHead
Aug 11, 2012 06:40 AM
vango
Nov 22, 2011 11:14 AM
Diver110
May 25, 2011 12:34 AM
cubpak89
8
May 10, 2011 11:31 PM
procarry21
Mar 24, 2010 01:55 PM
