Some play in steering
Old Dec 19, 2006 | 12:18 PM
Godti's Avatar
Default Some play in steering
I have a '98 Z71. I picked it up about 3 months ago. I had everything checked out on the vehicle before I bought it, and it checked out okay except for a few little things (1 tail light was burnt out, and the spring on the passenger door was broken). Anyways, the steering is a little sloppy and the the wheel is slightly off center when going straight down the road. I have about 1/2 an inch to 1 inch of play in the wheel, so I would like to get this fixed, but not sure exactly what it would be from. Could anyone tell me or has anyone else had this issue? If I replace all the ball joints, tie rod ends, etc. Would this fix the issue, or is it in the steering box??
Old Dec 19, 2006 | 06:31 PM
smoke20's Avatar
Default RE: Some play in steering
I would go the ie rod end route. You can look and see if they have alot of play by getting someone to move steering wheel while you look. I will be obvious, there should be no play. I would think if it was in the steering box you might actually feel a clunk in the steering if teeth were missing. I don't think there is really anywhere to get slop in the steering box.
Old Dec 19, 2006 | 06:59 PM
Godti's Avatar
Ok, I will look into replacing the tie rod ends and the pitman arm.
Old Dec 21, 2006 | 02:12 PM
Godti's Avatar
So I have been doing a little more research, and have read some articles on replacing a steering sensor that assists the power steering. Apparently they are quite common to go (at least in the '98's). Has anyone else heard of this?
Old Dec 25, 2006 | 06:19 PM
02 Z71's Avatar
My 98 had steering issues. Tie rods and pitmans at 50,000. Watch out for alignment. In spec is not good enough. After bad tire wear on new tires, I found a guy who really knew how to align this truck.
Regarding steering sensor - not related to play in the wheel. When going around an easy curve at say 40mph,the steeringwould suddenly jerk like you hit a patch of ice. Was driving me crazy! Local shopsaid steering box or something for $370.
Did a quick search and found the EVO (electronic variable orifice ?)sensor problem. Some said replace - about $30 I think. Another said pull itout, clean and WD40, re-install. Did it, 20 minutes, hard part was laying on the floor looking up and getting the wiring connector off. 5000 miles later, noproblems. This sensor is under the dash on the steering column. Hope this helps.
Old Dec 27, 2006 | 05:32 AM
under construction's Avatar
is that for only the 98s?
Old Dec 27, 2006 | 07:46 PM
sc64chevy's Avatar
The idler arms on these trucks were notorious for being worn out to. I had a 97 that needed a new one at 50k.
likearock@13
Jan 21, 2013 07:24 PM
Chzyrider
Vehicles for Sale
Apr 10, 2011 10:08 PM
jigsaw71
Jul 22, 2009 09:44 PM
xtmsports
Oct 19, 2007 06:31 PM
Vette Trash
Dec 10, 2006 01:44 AM
