Spark Plug Wires
Old Feb 15, 2008 | 01:15 PM
Cvtsax's Avatar
Default Spark Plug Wires
I was just wondering what kind of wires you guys think are good....What you guys have used or whatever. Or should I just stick with the stock AC Delco ones. Thanks
Old Feb 15, 2008 | 01:42 PM
jcbst12's Avatar
Default RE: Spark Plug Wires
Just go with AC Delco. I would go with 8mm or so or get colored wires if you really wanted something different. But buying expensive "performance" wires won't do all that much unless you have a modified motor, larger injectors, NOS, or Forced Induction.
Save you money for something you really want for your truck.
Old Aug 18, 2008 | 01:19 PM
JB 2004's Avatar
Granatelli 0 ohm 8 mm plug wires and G3 plugs. Now you can forget that for a long time
May be a small increase in mileage over a long run.( Interstste )
Old Aug 18, 2008 | 04:09 PM
wellmax's Avatar
Member
stick with AC Delco, use all AC Delco tuneup parts.
changing brands can trigger senors thatmay give you a engine service light.
why take the chance
Old Aug 18, 2008 | 07:24 PM
rxsteven's Avatar
AC Delco are fine the wires are so short high dollar wires dont make much of a difference.
Old Aug 18, 2008 | 08:04 PM
wickedlester's Avatar
I bought MSD plug wires a few weeks ago, no complaints.
I agree with most everybody though, the plugs are short so high performance stuff won't make much of a difference at all.
You should stick with ac delco. I do when I can, but I'm not going to buy something that is an inferior product for more money.
Old Aug 21, 2008 | 01:33 AM
zimsilverado's Avatar
I bought MSD wires. I have had good luck with them. Also, they were less than the GM ones.
Old Aug 21, 2008 | 09:02 AM
JB 2004's Avatar
THERE IS GOOD PLUG WIRES AND GOOD PLUGS ,YOU GET WHAT YOU PAY FOR.
THEN THERE IS BEST,E3 PLUGS,BOSCH PLUGS,NGK PLUGS,PLATINUM FOR SURE,AS MANY
GROUND STRAPS AS US CAN ( BOSCH + 4 ) A GOOD SET OF 0 OHM'S WIRES.
Old Aug 30, 2008 | 08:48 AM
GMCTRUCKS's Avatar
Member
I have MSD wires have had good luck with them in fact my whole ignition system is MSD but I have heard that Delco wires are good.
Old Aug 31, 2008 | 03:32 PM
DamnYankee's Avatar
For the record, the Gen III's have been dyno'd with stock and aftermarket wires and there were no differences shown. I run Taylor 409 race wires because of the underhood temps and the wires are huge. For basic applications, stock are fine.
