Spit and Sputter. Service light.
Old Jan 27, 2011 | 09:50 AM
RGHnRDY CHEVY's Avatar
Default Spit and Sputter. Service light.
Hey there! Just joined the forum, always good to have somewhere to turn to for opinions. Anyhow, have a 98 sierra Z71 with a 305. Truck has some problems Im tryin to get to the bottom of but this one just came up and is affecting the truck quite a bit. Had the codes pulled and its throwin P0131 twice. Say Im cruisin along and hit the gas to shift down a gear the rpms will drop and shell spit and sputter. This will even accur in neutral. Wont go past round 2500/3000 rpms in neutral. It will eventually get so bad that its nearly impossible to leave a red light until you re fire the truck. Dosnt act up as bad in cold tempatures. Just replaced the fuel filter yesterday in hopes of a solution. Any thoughts?
Old Jan 27, 2011 | 11:03 AM
Your code is explained here...
http://www.obd-codes.com/p0131
Old Jan 27, 2011 | 11:12 AM
I viewed and understand that. But from the research ive done from the links on that page people that changed the o2 sensor still had the problem.
From what i understand there is multiple things that could throw that o2 sensor off to make it throw a code? So im just searching for different possibilities if any.
Old Jan 27, 2011 | 11:52 AM
Yeah sometimes the codes are a little vague as to what the issue is. Have you had your converter checked? Any muffler shop should check it for free. I would start there and then if it isn't that get the multimeter out and start checking sensors one by one.
Old Jan 27, 2011 | 12:11 PM
Converter? As in torque converter? I havent had anything checked. Just the fuel filter.
Old Jan 27, 2011 | 12:31 PM
Or are you talkin bout my cats?
Old Jan 27, 2011 | 04:22 PM
Yes the catalytic converter. Make sure it isn't clogged.
lorennmeg
Sep 4, 2011 12:04 PM
HarderThanRocks
19
Apr 14, 2010 05:15 PM
Chuck1960
Dec 21, 2009 06:49 PM
Texas Mobil 219
Oct 4, 2009 04:19 AM
Regal105
15
Apr 18, 2007 06:56 PM
