Starting Problem...
Old Nov 19, 2007 | 05:34 PM
98Silverado4Ever's Avatar
Default Starting Problem...
I have a 98 Silverado Shortbed Z71 w/a 350 Vortec engine w/98k miles. It has recently been starting w/some problems. I used to barely turn the key and it would start. Now when I turn the key it cranks for about 2-3 seconds then starts. Any suggestions before I start replacing parts?? I replaced the alternator less than 2 weeks ago.
Old Nov 19, 2007 | 05:43 PM
Argon's Avatar
Default RE: Starting Problem...
you need to get the fuel pressure checked...it may be low,or bleeding off
Old Dec 1, 2007 | 08:59 PM
ffemt3100's Avatar
Do you think that would be my problem?
https://www.truckforums.com/m_28317/tm.htm
Now mine though takes about 5-7 seconds to start?
What do you guys think?
Old Dec 2, 2007 | 12:41 AM
racethisz71's Avatar
it might be like a jeep the fuel regulator doesnt hold the pressure so it has to build up , try turning you key a couple times and let the fuel pump run then crank it to see if it helps
gmchevy
Jan 13, 2007 07:02 PM
nathanfox83
Dec 26, 2006 08:25 PM
the dude27
Dec 9, 2006 02:32 AM
dankoos
Oct 7, 2006 09:42 AM
TonyBoneKhang
Sep 19, 2005 10:35 PM
