Synthetic Oils?
Old Feb 8, 2008 | 11:00 PM
  #11
72charger's Avatar
Default RE: Synthetic Oils?
The only way to really clean all the old stuff out is to change the oil to what you want, run it for a few minutes, change the oil again, run it again, and change the oil again. Changing the oil filters every time you do it as well. Not very practical to do this though so I'd recommend just making sure you let it drain good, change the oil filter, and then just don't worry about it.
Old Feb 9, 2008 | 08:05 AM
  #12
donkeydan's Avatar
you guys should check out www.bobistheoilguy.com
Old Feb 9, 2008 | 08:17 AM
  #13
hunt4game29's Avatar
When you switch over to amsoil you buy and bottle of cleaner and drain a little oil out and then add the cleaner then you run your motor at like 2000 rpms for about 15 min. Then you drain the oil hot and it cleans it out. That is how asmoil has you do it. Also not sure if the dealer will switch to other stuff for you or not.
CaptanMacTavish
10
Mar 12, 2013 11:17 AM
09GMCSierra
10
Mar 4, 2011 06:22 AM
Worf
Feb 21, 2011 02:11 AM
Robbs10ext
Apr 29, 2008 01:12 PM
