Tow/Hual coming in and out
Old Nov 5, 2011 | 01:50 PM
Texasbuddie's Avatar
Default Tow/Hual coming in and out
I have a 2000 Silverado, the transmission is swapping to Tow/Hual on it's own. Sometimes it is in tow/hual when I start the truck and sometimes it will swap while driving. Any help would be appreciated.
Old Nov 5, 2011 | 04:24 PM
NullHead's Avatar
Perhaps take it to a dealer, or talk to someone who has a high end code scanner, like a TechII factory Gm scanner, and have them look through the computer modules on the truck and see if they have any codes.
Old Nov 5, 2011 | 07:02 PM
rmck490's Avatar
Before taking it to the dealer, I would suggest checking the wiring to the Tow/Haul button in the steering column. You may have a short to ground on the BCM side of the wiring. It's common for the wires to get pinched near the shift lever. If you don't find a frayed wire, then take it in. Otherwise you may be able to fix it yourself.
The Tow/Haul switch simply grounds the circuit momentarily. In-turn the BCM reads this signal and will command the IPC to turn on the Tow/Haul light. The BCM also sends a signal to the PCM which sets the transmission to the requested mode. Pushing the button again completes the same process except it turns off the haul mode.
Old Nov 8, 2011 | 09:31 PM
It was a broken wire. Made repairs working fine now. Thanks for the help.
aDcAT 13
Jan 12, 2008 08:56 PM
2500_DW
31
Dec 10, 2007 06:02 AM
Motocrossdude
Nov 27, 2006 10:46 PM
aDcAT 13
Oct 1, 2006 05:25 PM
aDcAT 13
Sep 28, 2006 09:53 PM
