Truck Shifts late
Old Mar 26, 2011 | 08:37 PM
derbytruck129@aol.com's Avatar
Default Truck Shifts late
I have a 1993 Chevy Silverado 2500 4x4 that the motor went bad in... It sat all winter outside with the motor pulled out... When it warmed up I put the new motor in it... When I first drove it after having it hooked up I put, it didn't shift until way late... Its getting a little better but I've driven it about 100 miles and its not right... The fluid was low but I put a bottle of Lucas in it and enough trans fluid to make it right but it still aint right... It shifts at about 4000 rpms at a medium acceleration... Help me out...
Old Mar 29, 2011 | 04:30 AM
jvp's Avatar
jvp
Member
Did the trans act up before it sat all winter?
Change all the transmission fluid and put in a new filter. It just might be possible that you got some mositure in the tranny, and trannys hate water.
Double check all you connections and vacume hoses, if you find a bad on junk it hoses are cheap.
good luck
jvp
Old Mar 29, 2011 | 06:53 AM
JVP covered it all. Get your transmission up to operating temperature and drop the pan.
Some fresh new fluid and a new filter should fix it right up.
Old Mar 29, 2011 | 12:16 PM
Copy that!! It was fine before it sat all winter... Thanks for the help guys...
bluchev2368
Aug 23, 2010 07:16 PM
Chuck1960
Dec 21, 2009 06:49 PM
geoffrey0104
Jun 14, 2007 07:06 PM
unclejunk
Jan 8, 2007 11:49 AM
desertwest
Dec 27, 2006 12:24 AM
