truck stalls
Old Jun 14, 2012 | 07:37 PM
Julie Renfro Mahnesmith's Avatar
Default truck stalls
got a 1991 chevy half ton 4x4 you will be going down the road and it will die. The fuel pump won;t work . sometimes it wont start until u try it 3 or 4 times. then it might start and run allday. any sugestions? when it dies u can pour gas in the carb and it will start but dies
Old Jun 15, 2012 | 07:15 AM
johntaps's Avatar
Former Sponsor
Post truck stalls
Hello and welcome to the Forum..
Have you clean your carburetor before? Try to clean out the carb and then try again..
Old Jun 16, 2012 | 04:36 PM
TMW's Avatar
TMW
On the drivers side below the dash you have a 5 amp fuse. I'm not sure what it is labeled maybe Ign. Replace it whether it looks good or not. The reason I say this is that I had a 91 4x4 and after the tranny was replaced it blew that fuse and like you when gas was poured down the TBI it would fire then shut down. The fuse was blown. That fuse also powers the clutch in the auto transmission. I found the wires smashed in the tranny and when they made contact with the metal it would blow the 5 amp fuse but not a 10 amp. I think you have a bad connection in the fuse panel or wiring. Worth a try anyway. I gave my truck to my son and he still drives it.
eaa1964
10
Sep 21, 2010 06:10 PM
Soah
9
Nov 23, 2007 07:27 PM
gmight
Jul 27, 2006 11:24 AM
eaa1964
May 21, 2006 03:19 PM
Polaris 500
Jan 25, 2006 01:48 AM
