Truck won't Start???
Old Jan 5, 2007 | 02:35 PM
sermon's Avatar
Default Truck won't Start???
have a 99 NBS GMC Sierra. I went to start it last night and everything seemed to short out and drain the battery. I let it sit for a minute and the lights inside came back on like normal. Now i can put the key in and turn one click and all the dash lights will come on just fine. Here is the problem. if i turn the key 2 clicks to the ON position, everything goes black like the battery was disconected. I can also here a quiet continuous clicking coming from under the hood. I tried reseting the battery as well as jumping the battery. It seems as if the battery is fine but something is wrong with the starter or ignition. Or maybe some sort of short?If anyone has any ideas, please let me know. Thanks
Old Jan 5, 2007 | 03:20 PM
chevy1224's Avatar
Default RE: Truck won't Start???
I was puttin in my sat. radio the other day and left the key on for too long. I had the same problem starting it. That clicking is the solenoid in the starter. I hooked my truck up to my brothers (sad day when dodge fixes chevy) truck and had him keep his at about 2500 rmps for a min. or so, and then cranked mine. It started right up. After you get it runnin leave it alone, or it will die. Just let it idle for 15 to 20 mins. and you should be fine.
Old Jan 5, 2007 | 04:28 PM
sermon's Avatar
I tried jumpin it from my buddies chevy but it did nothing. I'm stuck i think?
Old Jan 5, 2007 | 09:52 PM
chevy1224's Avatar
Also, I was reading that if you have a bad disributer and/or cap that it could cut off power to the cylnders and your truck wont start. Check you fuses, battery, batt. Cable, and anything else electrical that has to do with the starter. Good luck buddy...
Old Jan 5, 2007 | 10:34 PM
smoke20's Avatar
Could be a poor ground. check engine to frame ground. On my last truck it got against exhaust and burnt through.
Old Jan 6, 2007 | 12:19 AM
99z71325ci's Avatar
do you have a manual transmission? it sounds like your ignition is being overrided by a system cutout. like if you leave it in gear the engine wont start. maybe one of these sensors has come out of adjustment or shorted out.
Old Jan 7, 2007 | 01:48 AM
sc64chevy's Avatar
If it has the original battery terminals on the wires with rubber coating, cut them off and put new ones on the cables they are prone to corroding inside and will cause the problems your talking about.
jackedupride
14
Jan 1, 2012 09:55 AM
gmdemo06
Nov 25, 2007 11:30 AM
sermon
Jan 5, 2007 02:46 PM
scooter
May 8, 2006 03:21 PM
snap_on_tools
Dec 15, 2005 10:05 PM
