Trying to go old school
Old Oct 26, 2008 | 10:42 PM
TP5.3's Avatar
Default Trying to go old school
I have an 02 Z71 stepside with the 5.3and I am looking to make it a quick truck. Im 18 so a lot of the guys I see with these chevys just get a throttle body spacer a programmer and a cold air intake. Thats all good and fine but I just got done building a sb 350 and put it in my dads 1970 olds cutlass and I want to do more to it. I would like some ideas on a good cam, lifters, valve springs, pushrods and rocker arms combination. If yall know anyother addons that have worked well mention those too thanks
Old Oct 27, 2008 | 01:14 AM
jcormier89's Avatar
Default RE: Trying to go old school
front end turbo. damn yankee's truck is badass...take a gander
Old Oct 27, 2008 | 12:37 PM
DamnYankee's Avatar
eh - it's slow
Old Oct 28, 2008 | 03:55 PM
rxsteven's Avatar
ORIGINAL: DamnYankee
eh - it's slow
Compared to what?
Old Oct 28, 2008 | 04:50 PM
DamnYankee's Avatar
Just kidding - it does all right.
Old Oct 28, 2008 | 06:11 PM
tylerz71's Avatar
ORIGINAL: TP5.3
Take off the 35's.
Get a custom tune.
Vette/aftermarket servos.
intake/exhaust.
Then see how much more you want to do.
Old Oct 28, 2008 | 09:07 PM
mitch cobb racing's Avatar
turbo, keep everything else stock with 5 or 10 pounds and you will have plenty of power!!! you might have to do some trans work, but nothing major, for now at least
Old Oct 29, 2008 | 12:41 AM
jcormier89's Avatar
i say...drop ina helicopter turbine engine in the bed of your truck. no engine or tranny work required...
but seriosuly, what 1/4 mile time you runnin yankee? you tried it at the track at all?
Old Oct 29, 2008 | 06:52 AM
DamnYankee's Avatar
Only ran it once since the turbo install...best was a 12.5. That was spinning drag radials off the line and tapping the brakes a couple times mid track because the back end started getting loose. It was also in 90° weather with 60% humidity. So with this cooler weather, I should be low 12's or high 11's if I can hook. That's on 8 psi. Going to 12 or 14 psi soon, which will add another 80 - 120 hp and get me mid 11's. Again - if I can hook lol.
Old Oct 29, 2008 | 05:16 PM
rxsteven's Avatar
Can I have your truck when your done with it?
