Tune up time-hits a roadblock
Old Aug 24, 2007 | 07:06 PM
urnhart's Avatar
Default Tune up time-hits a roadblock
I have a 2002 2500 Silverado with the 6.0L What plug and wires does everyone suggest? Also Iam doing differential fluid wil the royal purple work on a vehicle with 75K miles?
Old Aug 24, 2007 | 07:14 PM
72charger's Avatar
Default RE: Tune up time
I don't remember what brand they are but I know it comes factory with iridiums. The plugs are supposed to be good for 100,000 miles though. Don't know about the wires. As far as the diff fluid, I highly recommend royal purple. I haven't tried it in my truck yet but I put that stuff in my 240sx and my Z28 and it worked great. The Z28 started whining after a couple hundred miles with it but after I added some posi-x (I think that's what it was... some kinda diff additive) it was perfect.
Old Aug 24, 2007 | 08:57 PM
Cracker's Avatar
I think Amsoil offers a dif fluid. After my last oil change, on 1.5 mpg more, everything in my truck will be Amsoil.
Old Aug 24, 2007 | 08:59 PM
chevy112488's Avatar
apparently its best to use the factory plugs, but i put bosch platinum/irridium fusion plugs in my truck and they are working great... only 500 miles so far but it idles smoother definitely
Old Aug 24, 2007 | 10:40 PM
72charger's Avatar
I've never tried Amsoil but I here good things about it. Though after trying Royal Purple I am a firm believer in spending the extra buck for that stuff! That stuff actually FIXED the tranny in my 240sx, no joke. It was making a crunch racket when I switched gears and kinda hard to shift unless I put the clutch in and waited about 2 seconds to put it in the next gear. The royal purple totally fixed it!! Never mind that it's like $12 a quart..........[&:]
Old Aug 25, 2007 | 01:26 PM
urnhart's Avatar
So the tune up hit a little road block, went to change the Diff fluid and after seeing the Diff cover I decided it needed to be replaced due to rust. The problem was the dealer came up with two rearend options 9.5 and 10.5 inch bought both thinking I would return the one I did not use but it turns out I have an 11.5 dealer has to order the 11.5 so I am SOL until Monday. It is always funny to hear a dealer say "I've never seen that before".
Does anyone have any plug wire suggestions, looking at Tayor, MSD and one that I saw on here I think JBA -SC_Chevy_installed and did a write up.
Old Aug 25, 2007 | 08:04 PM
72charger's Avatar
I'd just go with your basic Autozone wires. There is no performance gain to be had there.
Old Aug 26, 2007 | 06:14 AM
Argon's Avatar
Many choices on decent plugs...but don't go for gimmick plugs...just good ones.
Wires..get delco..or Belden...no thrifty shop wires.
Old Aug 26, 2007 | 08:24 AM
smoke20's Avatar
but also remember, larger wire, more spark. So look for something in the 9mm range.
Old Aug 26, 2007 | 01:50 PM
72charger's Avatar
Not to create an argument with you, but you won't get any more spark by installing bigger diameter plug wires. I did some research on that a while back and it is all up to the coils as far as how much spark your getting. I also know MANY people who have purchased the MSD wires or Accel wires and didn't notice any change at all, just to back up my point. It's a waste of money. When I get wires I usually just get the cheaper ones like Xact from Advance Auto Parts. They were just as good as anything else.
