-   -   Very weird problem, dome lights turn dash off, some interior lights not working (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/very-weird-problem-dome-lights-turn-dash-off-some-interior-lights-not-working-14059/)
dimmuborgir6nik6 Jun 29, 2010 12:11 AM
Went to install LED lights in my dome and map lights but the lights to my surprise were too small. These were said to be the exact replacements, so I popped them in, too small, pulled them out and didn't mind. Later on, I went to turn my AC on and noticed the AC speed and vent adjuster switches had no light. I then went to turn on my map light on and instead it shut off my dash lights.. I pressed all 4 overhead light buttons and there seemed to be a weird combination. Depending on if I turned on the dome light override or not, after pressing each of the 4 overhead buttons it would either turn them off, do nothing, or turn on/off my dash. Sometimes when I'd press them the lights would flicker but not stay on. Also noticed my steering wheel cruise control and radio buttons aren't lighting up. The only button that was illuminated was the bluetooth. I have no idea what kind of electrical related problem this could be! At one point or another the lights do illuminate so I know they have power. I figured it could be a polarity problem but tried a million ways of reinstalling the overhead lights and none made a difference. Help! :confused:
Mr_Shamrock Jun 29, 2010 06:43 AM
What exactly did you do, just replace the bulb? Sounds like a ground issue.
dimmuborgir6nik6 Jun 29, 2010 07:22 AM
That's what I'm thinking. I took out the old bulbs, just the 2 in the front for the map light, put the LED's in but they were too small so I took them back out and put the old lights back in. They worked normally until I realized this problem. Basically what's happening is when I turn on the maplight they don't go on, instead they turn off the dash lights. I had to move the contacts around a bit, I'm thinking maybe they're hitting up against another piece of metal?
Mr_Shamrock Jun 29, 2010 09:13 AM
Definitely the place to start looking. I had a bad ground in an older Chevy truck, actually it was totally disconnected, and my dash lights were going crazy! I wouldn't have believed it could cause all that had I not seen it.
dimmuborgir6nik6 Jun 29, 2010 09:22 AM
Thanks for telling me that, definitely gonna check for a bad ground somewhere. I hate electrical problems
dimmuborgir6nik6 Jun 29, 2010 07:04 PM
Removed overhead console, checked wiring, everything seems to be fine. Checked interior related fuses and they're fine. Still stumped
Mr_Shamrock Jun 29, 2010 07:59 PM
Which truck is doing this?
dimmuborgir6nik6 Jun 30, 2010 12:26 AM
The 2010 Silverado, forgot I had the Blazer listed on there. I had also put LED's in my Blazer though and there was no problem. It's a very strange problem, never encountered anything like this before
Mr_Shamrock Jun 30, 2010 07:08 AM
Is it still under warranty?
dimmuborgir6nik6 Jun 30, 2010 11:04 PM
Yep, bought it a few months ago. Bringing it back to the dealer to let them take a look at it, but they're booked until the end of the week.
