Weird problem FI
Old Feb 18, 2011 | 03:37 PM
uniongoon's Avatar
Default Weird problem FI
My 1999 new body style, 4.8 vortech 2WD Sierra has an issue which has plagued it since I bought it a couple years ago.
When it starts fresh in the day, it runs fine, then after warm up, I make multiple stops all day long, and often after warm up, when I have been stopped only a few (5-!0 minutes) the first 30 seconds, it wont fuel up, meaning I can only do very light throttle, if I step on it hard it chuggs and backfires, then it clears up in less than a minute and runs fine.
Vapour lock?
Old Feb 18, 2011 | 03:55 PM
chevychase's Avatar
Try cleaning mass air flow sensor first. Are you getting any codes?
Old Feb 18, 2011 | 11:15 PM
RUFFNECK4LYFE's Avatar
Bad O2 sensors can cause these symptoms. The sensors are not used during warm up or open loop, but when it goes into closed loop they are. Have a shop with a really good scan tool read your computer. Mine did this and didn't throw a code. But the scan tool showed both sensors low voltage meaning they were bad.
dimmuborgir6nik6
21
May 12, 2023 03:58 PM
Biohazed
Jan 15, 2010 07:06 PM
jcbst12
May 22, 2008 09:48 AM
chevy112488
May 9, 2007 11:53 AM
Chevyvehc
Nov 7, 2006 08:17 PM
