What is Amp draw HVAC motor on high?
I’ve been improving the hvac system on my 97 c1500.
I’ve cleaned the evaporator coils, plugged a couple of leaks, and charged up the system. I live in Dallas, TX and it is 105F today and my system is blowing 35F. However, I don’t think it is moving enough air. My fan switch has four speeds and I can hear four levels of air movement. I tested the voltage on the high speed setting and it was 13 plus volts. Then I tested the amps and the motor is pulling 17 amps. Is that too high? Is this original motor not turning as fast as it could because of wear? thanks! |
| All times are GMT -5. The time now is 06:08 AM. |
