wheel bearings????
Old Mar 25, 2008 | 07:29 PM
scotwea's Avatar
Default wheel bearings????
Hello, I've got a 1995 Chevy 1500, automatic, 350. When dring slow, there's a pulsing whistling, winding sound. When I speed up, the pulsing sound increases in timing but not in tandem with acceleration. Is it the wheel bearings??? Any suggestions where I should start to look for the problem? It doesnt sound like its coming from the engine. When idling, there's no sound, only while actual driving.
Thanks for any suggestions.
Regards
-Scott
Sacramento, CA
Old Mar 25, 2008 | 07:56 PM
MajorSilva's Avatar
Default RE: wheel bearings????
Either bad bearings or you have a house cat jammed in your engine bay.
Old Mar 26, 2008 | 05:59 AM
Argon's Avatar
sound like its from the rear?....maybe a pinion bearing or ring gear
at hiway speeds...does accelerating make it louder,and a coast soften it?
Old Mar 26, 2008 | 09:05 AM
04BLKCHEVY's Avatar
I had a whistling sound in the rear a year ago. It ended up being a bad drive shaft u-joint in the rear.
Old Mar 26, 2008 | 09:42 AM
rxsteven's Avatar
If you put in in neutral on the highway dose it still do it?
AaronBishop
Jul 10, 2009 06:25 PM
kcantrell
Jul 8, 2009 08:35 PM
chrisbmo2000
12
Feb 14, 2009 05:27 PM
goldguy
Dec 9, 2008 01:22 PM
tgalyean
10
Feb 15, 2008 09:29 AM
