whining noise
Old Mar 9, 2010 | 06:34 PM
silverado96's Avatar
Default whining noise
whats up guys i got a new noise thats buggin me. Whenever i hit the gas it makes a whining noise much like a bad power steering pump would. I though maybe it could be my power steering but it doesnt do it when im turning. Could it be the power steering? if not than any other idea what it could be? any feed back would be much ablidged.
Old Mar 9, 2010 | 10:20 PM
chrisbmo2000's Avatar
Well.....is the power steering fluid full? How about the Transmission fluid? the alternator or the water pump? Can you pinpoint the sound when you open the hood?
Old Mar 10, 2010 | 08:00 PM
RUFFNECK4LYFE's Avatar
Time for either the stethoscope or the old long 1/2" extension in hand and ear tool!
Old Mar 31, 2010 | 03:18 PM
farmer12091's Avatar
Member
i got the same one i think. i replaced my alternator water pump and have tried about everything. its hard ton pinpoint. almost sounds like its the ac pump for me
Old Mar 31, 2010 | 07:53 PM
Does it only do it when driving or in park as well?
Old Apr 1, 2010 | 08:38 AM
Member
both and it sucks cuz you cant make a truck sound big and bad with that noise always going off
Old Apr 1, 2010 | 12:10 PM
I would pull the belt off and start it up to see if the noise goes away. Don't let it run for a long time b/c you won't have any fan or water pump.
Old Apr 1, 2010 | 04:06 PM
timber74wolf's Avatar
Spray each pulley with a squirt of WD40. When it goes away you might have found it. Just my 2 cents.
Old Apr 1, 2010 | 07:30 PM
What he said. I've got a spinning noise that happens from time to time on my truck. Whenever I hear it I immediately grab the WD-40 and soak down everything including the belt. It'll go away for 3-4 months. I think mine is a spun alternator bearing though.
Old Mar 23, 2017 | 11:47 AM
usatruckdriver's Avatar
guys same thing happened to me. it's your ac bearing mostly and it's a bitch to replace.
Matt Eaves
Nov 1, 2017 07:34 AM
In2Trux
May 25, 2015 08:53 AM
90bronco351
May 18, 2009 09:19 PM
ahartend
Oct 22, 2008 09:28 AM
bigmike67217
Oct 30, 2007 06:39 PM
