will halo ring aftermarket headlights use the regular bulbs?
Old May 4, 2011 | 01:40 AM
chevyman99's Avatar
Default will halo ring aftermarket headlights use the regular bulbs?
hello, i was wondering if i bought a halo ring light kit for my 99 chevy silverado 1500, if the original bulbs for the truck would work in them, i ve looked at some kits that the low beam for the kit is an led light and just plugs in like the original light but what ablut the high beam? because in the kit it shows a hole where the bulb would go thru into the housing but it doesnt say or shw a light that goes into it. Any help with this will be greatly appreciated, Thank You.
Old May 4, 2011 | 09:00 AM
Each manufacture has done it a different way. Your best bet is the call the manufacture. But before you waste your time on the phone with them.. Insure that their light is DOT compliant or approved. Heavy fine if you get pulled over and the trooper can't see the DOT stamp on the lens.
carid
Member Group And Special Buys
Apr 21, 2015 06:35 AM
geekgame818
Apr 8, 2012 12:37 PM
zleehw
Jun 10, 2010 09:46 AM
Boy Blu
Oct 6, 2009 08:04 PM
