Wind noise from drivers side window
When I hit about 35-40 mph, I'm getting a lot of wind noise from the drivers side window ...like the window is cracked open a little. No noise on the passenger or rear windows.
Is there a cheap/quick fix?
I have the same problem with mine, but it is actually coming from the base of the windshield, not the driver's side door (though it sounds like it). Haven't come up with a solution for it yet.
Is the window actually going all the way up? You should be able to run your finger (or a pen, something small) along the inside of the seal and lift it back to see if the window is all the way up.
You could also check around your mirror on the outside, see if it's loose from the door itself.
screamingijit
Nov 21, 2008 01:51 PM
