Wind Noise
Old Jan 5, 2007 | 08:04 PM
gmsuv's Avatar
Default Wind Noise
I've got wind noise coming from the passenger side door at speeds over 50 mph on a 2000 Ext. Door hinge pins and sealsaregood so it can't bean alignment problem. Anybodyelse have this problem and how did you correct it?
Old Jan 5, 2007 | 09:59 PM
chevy1224's Avatar
Default RE: Wind Noise
Hmmm... Does your door always close good?Passenger side? I got rearended 5 or 6 months ago. I was stoped anda friend smashed into the back of me at about 30. For a whilethe door worked normally. Then out of the blue, it was rediculouly hard to close. You can slam it and it wont close sometimes. I think its a bent frame, but I dont really know. Havnt got it checked out. Just seein if you have the same symptoms as mine, to make sure that my entire truck is all jacked up from the wreck.
Old Jan 5, 2007 | 10:31 PM
smoke20's Avatar
My 05' has some wind noise from the rear doors, but I have a crew cab. It is not very loud though. Also I can feel the A/c coming from the rear seal of the door on the outside. I haven't really thought much about it, especially since I didn't notice it till warantee was out and it doesn't bother me. Probably a different issue but thought it might help. Anybody else experience this?
Old Jan 6, 2007 | 02:53 AM
under construction's Avatar
you sure you put up your window all the way? sometimes it looks like it up but its not...lol...
Old Sep 15, 2008 | 07:31 PM
robbkelly's Avatar
I have a 2005 2500hd with 24k miles on it. The driver door is harder to close - is there a fix/adjustment? It's an extended cab, so it closes against that door, but it still isn't as good as other (same model) trucks and not as good as passenger's.
I love my dodge because the doors shut so easy with a good thunk, but all the chevy's I've owned you have to slam them.
Old Sep 15, 2008 | 09:43 PM
Rhyse62's Avatar
Member
could your window have come off the track in a small or possibly out of align . if it was me i'd just turn the stereo up louder.
Old Sep 16, 2008 | 06:49 AM
HarderThanRocks's Avatar
Dude. Try rolling your window down and putting your knee on the lower half of the door and pull (in towards the cab) on the top of the door jam. Out here in Sicily all these GD Italians pry the doors open to break into your car.They dont bother breaking the windows,I guessjust prying your doors open is easier so they cansteal your STEERING WHEEL COVER and your CD case, NOT YOUR CD's, JUST THE CASE! Anyways..Thedoors on my truckwere a little noisy when I went home on leave and I used this method and they weny quiet again..
Old Sep 16, 2008 | 06:52 AM
Hold on a sec. Let me plug Dynamat real quick. Man, I put Dynamat on the inside of my doors and the cab of my truck is really quiet. Even with my mud tires..
Old Sep 16, 2008 | 08:08 AM
moose's Avatar
I agree. Wind noise usually is caused in some way by a window problem.
screamingijit
Nov 21, 2008 01:51 PM
davidl
15
Mar 14, 2008 10:14 AM
ropechoker
Sep 9, 2007 03:05 PM
SouthBayZ71
Jul 27, 2007 08:21 AM
jaxspellinar
Jul 24, 2007 07:33 PM
