windshield wipers timer problem
Old May 16, 2007 | 11:55 AM
cajunwoodrick's Avatar
Default windshield wipers timer problem
I have a windshield wiper timer problem sometimes I put the windshield wiper on the first position it should make one pass and wait a while for however many seconds then another pass but sometimes it stays on for 5 are ten minutes then cuts off ,is there somethingI can do about this problem,maybe somethinglike clean a contactor somewhere are something.Thanks its a 2003 Sierra 4.3l extended cab
Old May 16, 2007 | 06:08 PM
Argon's Avatar
Default RE: windshield wipers timer problem
The wiper module is likely corroded from water intrusion...its under the cowling..
Old May 17, 2007 | 06:38 AM
Thanks Argon as soon as I find out where is the cowling I will try to locate it thanks again for your reply and time.
Old May 17, 2007 | 09:54 AM
Argon's Avatar
Remove the wiper arms..and the cowling is the black plastic piece that hides the wiper linkages...remove that...and a metal shield under there...then you'll see the wiper motor.
The module is also the wiper motor "cover"
Old May 17, 2007 | 01:02 PM
Thanks very much Argon for all your help
kkingsley71
Dec 26, 2011 06:20 PM
shop2011
Sep 8, 2011 12:40 PM
beatlebailey50
Mar 22, 2009 11:38 PM
OLEGRAMPA
Oct 26, 2007 02:06 PM
ebaron
Apr 26, 2007 09:39 AM
