Commercial Trucks Semi-Trailers, Box Trucks... Any commercial trucks.
International 4700
Old 04-22-2015, 11:08 AM
jasong1645's Avatar
Default International 4700
I am entirely new to trucking and I just bought a 2001 International 4700 DT466e. This truck has been parked for 2 years.
I will be hauling feed and fertilizer with it, each bag weighing 25kg. The truck is completely factory spec with the Eaton 5 speed gearbox.
How much tons would be recommended that I could haul with this config, and or what would I need to change to be able to haul more as I am being paid per bag.
I need some advise please from the experienced..
Attached Thumbnails International 4700-att_1429718516493_img_20150415_093719.jpg
Old 04-22-2015, 02:30 PM
From what I learned working at a tool and die shop, most trucks can haul everything you need, the issue is going to be the local laws.
I know in Michigan, with a truck of that configuration, the front axle weight cannot exceed 15,400lbs and the rear cannot exceed 18,000lbs.
My suggestion would be to find a friend with a large scale and play around for a bit
Old 04-22-2015, 02:42 PM
jasong1645's Avatar
Thank you.
So based on what you said, and the laws, you could carry 33400lbs with that truck in Michigan? Is that how it is calculated?
Old 04-23-2015, 08:26 PM
I would check your ownership. Find out what your GVWR
Take your truck to a truck scale (full of fuel) and weight it.
Subtract that amount from your GVWR and that is how much you can load.
Be sure to balance the load and not let your front axle exceed 12,000lbs
NikoKesler
03-18-2011 03:52 PM
Helomaniac
01-31-2009 05:01 PM
MAAR
11-07-2008 03:48 PM
Quick Reply: International 4700
