Diesel Discuss heavy duty Diesel engines!
What Are the Most Common Skid Steer Issues?
Old Jun 26, 2023 | 08:14 AM
Oswin's Avatar
Default What Are the Most Common Skid Steer Issues?
Any heavy equipment will eventually face maintenance issues, and skid steer loaders are no exception. To keep your skid steer loader in top condition, you need to keep an eye on your skid steer loader's engine, hydraulics and controls. Some of the most important skid steer problems you may have in these categories and how to check them:
1. Engine Issues
When an engine doesn’t start properly, you’ll want to begin by inspecting the fuel system, as some of the most common issues start there. Typically, a skid steer’s fuel system features fuel filters, fuel lines and a tank, each requiring individual checks. If your skid steer runs on diesel, not changing the filters on their recommended maintenance schedule can lead to issues. For skid steers that operate in dusty environments, you’ll want to change the filters out more frequently to prevent engine breakdowns.
After checking the diesel fuel filters, you’ll want to move on to the fuel tank. When fuel can’t flow to the fuel injector from the tank, the engine’s operational ability can be affected. The fuel injectors can be common culprits for lack of proper fuel flow, so it’s crucial these injectors aren’t clogged with any materials.
Another common issue occurs when an engine’s glow plugs aren’t working properly. Since a skid steer’s glow plugs help warm the engine’s combustion chambers when it’s in a cold environment, they make it possible for the entire engine to function as intended. At times, these glow plugs can come loose, causing them not to warm the engine. After locating these plugs on both sides of the engine, see if they’re tightly attached.
Finally, ensure the engine’s throttle cable is securely attached to the throttle body. Occasionally, the cables can come loose, causing the engine not to run properly. To check how secure these cables are, take a second to look at both sides of the cable. The cables should be attached to the throttle body, usually located on the motor’s top front, and the accelerator.
2. Hydraulic Issues
Another primary culprit of skid steer issues is the hydraulic system. If the skid steer loader isn’t working correctly, the hydraulic fluid level is often at fault. Ensure the fluid level isn’t underfilled or overfilled, as hydraulic systems perform best when they have the exact amount of fluid recommended by the equipment’s manufacturer.
A clogged hydraulic fuel filter can also cause major issues in the skid steer’s performance. For example, if you notice your loader doesn’t have as much power as it used to have, the fluid filter might be clogged. A clogged filter blocks fluid from flowing freely, which impacts the loader’s power.
A hydraulic system’s pump is also crucial to the skid steer’s proper functioning. If it’s not working properly and it’s a belt-driven model, you can check to see if the belts are in good condition and tightly secured. If they’re worn or loose, they can affect the hydraulic system’s performance significantly.
One of the most crucial checks is to look for loose fittings or leaks in the hydraulic lines, as they affect the hydraulic system’s performance. Before checking both of these factors, pressurize the hydraulic system and ensure the pump and engine are running. When the system’s fluid is under pressure, you’ll be much more likely to see any pinhole leaks. While conducting this check, ensure you’re wearing gloves and safety goggles to protect yourself from injuries due to the high pressure.
After looking for leaks, you can also look at the fittings and seals on the control valves. When these seals are broken or the fittings have come loose, the hydraulic system’s performance will decrease. You can also check the valves, ensuring they fully open and close without difficulty.
When you want to keep your skid steer loader running at its best, our team of professionally trained technicians can fix your skid steer loader quickly as soon as you spot the signs of a skid steer loader problem, of course you are A good mechanic who can replace parts himself then I recommend john deere diagnostic software to easily find the ideal replacement part for your unit. Of course this is my personal suggestion,please contact me if you have any questions www.obd2.ltd.
Bones
Aug 4, 2020 10:34 AM
Sanddraggin
15
Feb 4, 2017 09:02 AM
gritsnsweettea
May 13, 2013 04:00 PM
NullHead
12
Feb 1, 2012 11:44 PM
JMack
Jun 7, 2009 02:01 AM
