Dodge Dakota Forum Discuss the Dodge Dakota here.
Bouncing gauges
Old Oct 29, 2007 | 01:25 PM
mako15's Avatar
Default Bouncing gauges
I had a short in my trailer that took out the reg position tail lights. Replaced bad fuse and ever since ALL of the gauges bounce in a tempo that seems like the hazard tempo. None of the readings are true, all bounce at same time, differing amounts. Anybody have a clue?????? thanks
Old Oct 29, 2007 | 01:27 PM
mako15's Avatar
Default RE: Bouncing gauges
Oops went too fast and missed checking to Notify box. Mako15
Old May 10, 2008 | 11:35 AM
vernjeggies's Avatar
i had the same sort of problem with my 93 honda accord.. i was told that it was either a bad ground (you might have to look pretty hard for that one) or that the instrument cluster was shorted and needed to be replaced... id suggest checking for the ground and then check out new clusters. hopefully that helps
03TEXASEDITION
Apr 17, 2007 12:19 PM
dpriceis
Mar 29, 2007 03:15 AM
HETS1
Feb 16, 2007 03:00 AM
dpriceis
Dec 28, 2006 11:29 PM
KEVIN
May 16, 2006 01:40 PM
