1999 ram
Old Jul 12, 2004 | 02:22 PM
jds313's Avatar
Default 1999 ram
<UL>
<LI>the speedometer and cruise control is also notworking and stopped functioning at the same time as the ABS/Brake light came on. </LI>[/list]
</P>
Any help Thanks </P>
David</P><edited><editID>jds313</editID><editDate>38180.5164930556</editDate></edited>
Old Aug 11, 2006 | 11:41 AM
unclegus's Avatar
Default RE: 1999 ram
There is a sensor in the rear end (I know, it sounds strange but this happened to me.). not sure what it's called. Change or get it changed. If you should change the fluids in the rear end be sure to add special additive for limited slip diff. otherwise you'll get a strange reaction when making a tight turn and eventually burn up rr
Old Aug 15, 2006 | 02:09 PM
Patrick's Avatar
try checking out dodgeforum.com... lots of good ram info there!
Sid Lincoln
Jan 6, 2014 05:18 AM
BCCC
Mar 2, 2008 02:03 PM
mbaldwin
Apr 8, 2007 08:16 PM
dch47
Apr 5, 2005 10:08 PM
tedprice
May 30, 2004 12:29 PM
