Dodge/ Ram General Tech Dodge tech talk within.
1999 Dodge ram 1500 4x4
Old Jun 8, 2006 | 04:39 AM
mbaldwin's Avatar
Default 1999 Dodge ram 1500 4x4
I have a 1999 Dodge Ram 1500 4x4 5.2 liter. The ABS light stays on along with the Brake light. The speedometer stopped working along with the odometer and cruise control. I think it would be the ABS speed sensor on the rear differential, but I am not positive. Any help would be greatly appreciated. Thanks
Old Apr 8, 2007 | 08:16 PM
Freewill1959's Avatar
Default RE: 1999 Dodge ram 1500 4x4
The speed odometer is a sensor located on the tail shaft of the transmission.With a ohm meter unplug and check for resistance, if you have resistance then re connect and pin connectors with ignition on. The cruise is located under battery box. First I would get some di-electric grease from parts storeand a Haynes auto repair manuel. You didn't mention if check engine light was on or not, so it is probably a loose or dirty connection. Good luck
crawdad
Vehicles for Sale
Dec 29, 2011 06:18 PM
brokentine05
Jan 22, 2009 11:50 AM
brokentine05
Vehicles for Sale
Jan 22, 2009 11:47 AM
mrhaney
Vehicles for Sale
Aug 27, 2006 10:12 AM
dch47
Apr 5, 2005 10:08 PM
