2002 1500 Ram AC will not work while idling.
Old Jul 8, 2009 | 12:35 AM
btelin's Avatar
Default 2002 1500 Ram AC will not work while idling.
2002 1500 Ram AC will not work while idling. Works fine while driving and the engine light is on.
Old Jul 8, 2009 | 07:13 AM
Could be a fan issue not pulling enough air over the condensor at idle. Do you have an electric or manual fan? How is the engine temp at idle?
Old Jul 8, 2009 | 10:14 AM
btelin's Avatar
Belt driven fan and the temp is low when idling.
Old Jul 8, 2009 | 12:50 PM
If the fan clutch checks out ok, then more than likely you have a condensor issue. Check to make sure you didn't suck up a plastic bag or anything else in front of the condensor. Also check the fins on the condensor to see if it might have gotten damaged by something.
Old Jul 8, 2009 | 07:46 PM
btelin's Avatar
All looks fine. AC works great when NOT idling.
Old Jul 8, 2009 | 08:04 PM
Some trucks have an electrical fan as well as a belt driven fan. Could this be the case?
Old Jul 8, 2009 | 08:22 PM
Actually I think it is...I did a search and there are alot of articles about the condenser cooling fan and relay location on 2002 Rams. Check your condenser fan.
Old Jul 8, 2009 | 08:23 PM
It should look like this...
Old Jul 9, 2009 | 03:09 PM
Did you ever find out what it was?
flipsideafter
16
Sep 3, 2020 07:41 PM
HomeR365
Nov 7, 2011 07:58 AM
daryl
Sep 10, 2008 04:32 AM
desert bee
Automotive Parts Wanted
Oct 28, 2006 01:35 AM
ace
Aug 10, 2005 06:45 PM
