2009 Hemi intermittent front brake drag
Hi new to the forum. I have a 2009 Hemi that occasionally drags the right front brake. First time this happened it pulled left, shook the steering wheel and smelled the right front pads. Also of course the wheel was smoking hot. After letting it cool down and checking for stuck caliper, couldn't find a thing. Then it drove fine for days and today it did the same after driving for about 40 minutes. I pulled over, let it cool and low and behold, the caliper worked fine all the way home. I am confused. I read about the rubber brake lines issue. Could it be that, ruptured liner in the rubber brake portion of the line? Is that why it is always the same side that does it (right front) The left and the rears seem fine. Anybody else experienced similar things with this truck?
It's going in under warranty, but I would appreciate any comments. Great forum. Great information. |
Originally Posted by Gootch
(Post 60425)
Hi new to the forum. I have a 2009 Hemi that occasionally drags the right front brake. First time this happened it pulled left, shook the steering wheel and smelled the right front pads. Also of course the wheel was smoking hot. After letting it cool down and checking for stuck caliper, couldn't find a thing. Then it drove fine for days and today it did the same after driving for about 40 minutes. I pulled over, let it cool and low and behold, the caliper worked fine all hid kits the way home. I am confused. I read about the rubber brake lines issue. Could it be that, ruptured liner in the rubber brake portion of the line? Is that why it is always the same side that does it (right front) The left and the rears seem fine. Anybody else experienced similar things with this truck?
Maybe the flex brake line at the front wheel. Should be replaced in pairs.If thats the problem
