85 ram fires but dont run.?
Old Jan 18, 2010 | 05:03 PM
polaris989's Avatar
Default 85 ram fires but dont run.?
ive gone through a new starter,, ignition switch battery fuel pump, a resistor, can figure it out. it has fuel and spark. but it only fires and wont run. HELP
Old May 7, 2010 | 03:26 PM
moparchild5.7's Avatar
I had the same problem with my 85 and it was a grounding issue. We took a ground wire from the batterey ran it to the front of the truck and grounded it to the metal and it worked for us.
Old Jul 16, 2010 | 12:07 AM
mikesheldon's Avatar
Banned
(1) loose or damaged wiring in the ignition system.
(2) intake manifold vacuum leaks make sure all mounting bolts/nuts are tight and all vacuum hoses connected to the manifold are attached properly and in good condition.
(3) faulty idle control system.
(4) faulty emissions or engine control systems.
jswordy
23
Jul 18, 2022 07:54 AM
mcboo_Sierra
Dec 30, 2010 05:25 PM
imakedirtlookgood21
May 21, 2008 05:12 PM
imakedirtlookgood21
19
Apr 13, 2008 04:39 PM
imakedirtlookgood21
Apr 6, 2008 04:22 PM
