jacqueshatler29 |
07-11-2012 04:41 AM |
most probably they will be hyper-flashing but then also i would suggest you an pair of 6 Ohm 50W LED Load Resistors for LED Turn Signal Light Fix or LED License Plate Lights. These 6 Ohm, 50 Watt LED load resistors will work on any vehicle and can be connected across the turn signal bulbs or License Plate Lights to simulate the load of a regular filament bulb (2 Amp load). This will solve LED related turn signal lights or license plate light problems such as hyper flashing, no flashing or burnt out bulb indications. One LED resistor is required for each turn signal bulb or each license plate light bulb.
