Led turn signals question
Old Apr 8, 2012 | 12:35 PM
geekgame818's Avatar
Default Led turn signals question
Some websites recommend a pair of load resistors for LED turn signal lights. Will it work or burn out faster if I don't get load resistors?
Old Apr 13, 2012 | 08:10 AM
97drexelgrad's Avatar
no, the lights/and LEDs will hyperflash as they do if you had one bulb burn out.
Old Jul 11, 2012 | 04:41 AM
jacqueshatler29's Avatar
most probably they will be hyper-flashing but then also i would suggest you an pair of 6 Ohm 50W LED Load Resistors for LED Turn Signal Light Fix or LED License Plate Lights. These 6 Ohm, 50 Watt LED load resistors will work on any vehicle and can be connected across the turn signal bulbs or License Plate Lights to simulate the load of a regular filament bulb (2 Amp load). This will solve LED related turn signal lights or license plate light problems such as hyper flashing, no flashing or burnt out bulb indications. One LED resistor is required for each turn signal bulb or each license plate light bulb.
Downhand Dan
May 21, 2010 12:22 PM
Downhand Dan
Feb 24, 2010 04:42 PM
Lovemydiesel
Jan 24, 2009 07:07 AM
daryl
Sep 10, 2008 04:32 AM
bobbie53
Jun 1, 2007 01:25 PM
