Possible trans leak?
Old Aug 14, 2010 | 02:04 PM
LightningStrong's Avatar
Member
Default Possible trans leak?
Hello, been a while since I've been on the forums. I just picked up a '95 Dodge Ram 1500 with the 5.9L gas engine.
I noticed after I run the truck for a while, a small puddle of fluid ended up on the driveway. At first I thought it was oil, but then I looked under the truck to see if I could find the leak. I found out that there is a small drip-drop leak right by the universal joint towards the front.
I am thinking there is a bad gasket or something of that nature. Anyone else ever experienced this before?
Old Sep 6, 2010 | 01:12 PM
Member
Originally Posted by rdcancer86
May be it has happened because of loose connection of oil pump.
Please go to the dealer, from where you buy it and repair it soon.
Good day, and enjoy the safe driving.
I took it to my mechanic (not a Dodge dealer). There was a bad gasket and it wasn't just trans fluid, there was a small oil leak and a small coolant leak. $2800 in repairs.
This should last me for a while though, eh?
Old Jan 14, 2011 | 06:38 AM
AbleSmith's Avatar
Banned
There might be problem with pan gasket, wheather pan gasket is leaking because of having too much fluid, check wheather the leak is from transmission or in the final drive gear box
Old Feb 22, 2011 | 04:08 AM
atul1's Avatar
This leak could be because of broken seal and faulty installation, if it is major leak then you will have to take you car to the mechanic to fix the problem, This oil leak mainly caused due to loosening of bolts which fix the valve covers, just tightening the bolts will solve your problem.
tinkertruckin
Mar 31, 2012 08:36 AM
LightningStrong
Sep 8, 2007 01:03 PM
endura
Jul 23, 2007 08:07 PM
stopspazinout
Jun 28, 2007 06:50 PM
LightningStrong
Jun 18, 2007 06:32 AM
