Tranny not shifting
Old Jan 31, 2010 | 07:05 PM
dodgedude's Avatar
Default Tranny not shifting
I have a 2001 dodge ram 1500 with a 5.9 liter moter in it. A while back the tranny had messed up on my way back from a hour drive. It had sounded like a monkey with a sledge hammer in there. It would not shift from 1st gear. I had recently mess with it to see if it was anything simpler than rebuilding the tranny. I used some Marvel mystery oil and some lucus transmission stuff to help with sticky valves. That did work a little bit. When the tranny fluid is cold it will run good but when it gets warmed up it will not shift right. I had tried manually shifting it from 1 to 2 and then to drive (3-4) and it will shift sometimes and others it will not so if you can help me with it I will appreciate it.
Old Feb 22, 2010 | 03:06 PM
Hollonator's Avatar
i had the exact same truck and it did that when i bought it. we took it to a tranny shop and they replaced a $400 sensor, ran good as new.
Old May 22, 2010 | 12:21 PM
Nando Vazquez's Avatar
I have the same problem, what sensor did you replace?
efield
May 20, 2015 05:53 PM
03chevy2
Jun 19, 2013 09:54 PM
fallingup693
Jan 22, 2012 06:29 AM
montanaf350
Sep 15, 2007 02:33 PM
vj226966
Apr 7, 2007 12:18 AM
