Engine suddenly very loud with slight knock
Driving home over the weekend, my 96 Ram suddenly got really loud, and started a minor knock. It sounds like engine noise, not exhaust or other usual suspects. The sound itself does not sound like something with a good outcome...
However, I drove home towing a a heavy horse trailer with horses, and did not lose oil pressure or power. Any thoughts on where to start? |
Originally Posted by longyellowbus
(Post 59809)
Because of low oil pressure lifters, valve lash adjusters, variable valve train adjuster makes loud noise. kindly check all these things to solve problem
if its a cumins turbo deisel there is a dowel pin in the block behind the timing cover that likes to fall out and get slapped around by the timing set and can possibly get jammed in the gears..just a suggestion if you find nothing else to be wrong..did your exhaust fall off ??
These problem causes due to low oil pressure lifters,turbo deisel there is a dowel pin in the block behind the timing cover go to your dealer tell the problem or u take it to the company service center. They will solve your problem.
This would be the problem due to the jam in the engine and this would be creating problem.
| All times are GMT -5. The time now is 09:38 AM. |
