Dodge/ Ram How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
1978 dodge alternator...
Old Dec 19, 2013 | 02:40 PM
78powerwagon's Avatar
Default 1978 dodge alternator...
i have a 1978 dodge 100 4x4...and the battery will not stayed charged (new battery) i will jump the truck and it will run fine but if i cut it off it just clicks when i try to start it again. I have replaced the alternator and voltage regulator the other day with out any luck. i have put a meter on the alternator and it says im putting out 13v but its not getting to the battery.
so i was wondering what you guys might think is my problem.
Old Dec 20, 2013 | 02:41 PM
With the truck turned off. Disconnect the positive cable from the battery and use a multimeter between the cable and the positive post to see if there is a draw on your battery
Etxlady
Nov 9, 2009 06:48 PM
Etxlady
Nov 9, 2009 06:43 PM
isaac_22
Dec 24, 2007 12:33 PM
aklifer
Aug 30, 2007 04:21 PM
JSMConstruction
May 14, 2004 07:52 PM
