Dodge/ Ram How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
Need Help PLEASE
Old Jul 4, 2011 | 03:40 PM
kamokid70's Avatar
Default Need Help PLEASE
i have a 1988 Dodge Dakota have tried everything i can think of , i broke a rear brake line after replacing it cant get brakes to build up put 2 master cylinders on , changed power booster ,cleaned n adjusted rear brakes , cleaned n checked front brakes , i have tried resetting proportional valve still no luck PLEASE HELP
Old Jul 4, 2011 | 07:09 PM
Welcome to TF
Old Nov 14, 2011 | 11:51 AM
MOTORHEAD8835's Avatar
I'm assuming the brakes were bled & in the correct order after the line was replaced? Get a helper & start Bleeding the air out @ the passenger rear , then the drivers rear , then passenger front & the drivers front last. Sounds like air in the system.
Old Sep 5, 2012 | 11:27 PM
Michaelleonel321's Avatar
Exactly, there must be air in the system. You should blow the air out.
GMC58
Apr 24, 2008 02:50 AM
5.7vortec
Mar 18, 2008 12:49 PM
LOWLIFE
Feb 27, 2008 07:57 AM
NoMoChevrolegs
Jan 8, 2007 12:14 PM
houtz007
Automotive Parts Wanted
May 28, 2006 04:10 PM
