I Need Some Info/Help Please
Old Feb 26, 2008 | 11:11 PM
LOWLIFE's Avatar
Default I Need Some Info/Help Please
im thinking about buying a 1990 1500 Cheyenne V6 5spd. tomorrow, is it the same thing as the 1500 silverado? other than the front clip is there any difference? if i buy parts do ibuy for asilverado? i was looking on summite and there wasnt anything for this truck, but there wasALOT for the silverado..the guy said it was carburated and need's the injector's cleaned, so it has problems starting,would it be hard to convert it to a fuel injectedlt1/6spd? is there a kit?sorry about all the question's, i just want to know all i can about it before i buy it.. THANK'S
Old Feb 27, 2008 | 07:57 AM
jcbst12's Avatar
Default RE: I Need Some Info/Help Please
You truck is "throttle body injected" (TBI) not carborated. It is basically a "electric carborator" as it has injectors instead of carb jets.
Cheyenne, Silverado, Sierra are all the same except for the front clips and some emblems and options like trim and interior. Nothing more than that.
Best bet for that truck is swapping out the 6 banger for a 350. Keep the manual (5spd) because it will be much quicker and easier to swap motors. The motor will bolt right up to the transmission you have. Use a TBI 350 and you won't have to do much to make it work in your truck. Only thing you will have to do is have someone make a computer chip for the conversion. Go to TBIchips.com for this, they are cheap and work perfectly (get a performance chip and you can squeeze another 15-20 hp out of the 350).
I would get a 350, put centerbolt vortec heads on it and get the TBI chip for starters and you'll have a good running truck to play with and modify.
John_Chevy11
Aug 15, 2011 12:23 PM
Swis19
Aug 13, 2010 10:53 PM
nam6869usmc
Oct 10, 2007 07:55 PM
infinibot12
Jun 15, 2007 07:33 AM
CHEVY06
Mar 10, 2007 04:56 AM
