1998 Ford f150 Heater??
You need to fix your heater controller.
It is possible to have your heat with AC
Air Conditioning is basically the removal of moisture from the air. whether it's hot or cold.
Cool air feels cooler with the humidity (moisture) removed
Hot air can be delivered with no moisture (AC)
Are you talking the Heater Control Valve or replacing the Unit on the Dash Panel (3 *****)???
Im not Car savvy so i dont know what is what. But i do know im tired of driving around in 90+ degrees. I need my defroster on living in the northwest but i cant adjust the temp.......tired of being hot. Rolling down a window helps but with all the rain its not good either.
thanks
thanks
miltonluban
Aug 14, 2020 07:25 AM
