Sponsored by:
Sponsored by: Kumho
2011 4x4 front leveling kit
Old Feb 26, 2012 | 08:09 PM
daneiltx2011's Avatar
Default 2011 4x4 front leveling kit
my xl sits with the nose way down i want to level the truck out
does any one know of any good leveling kits in all price ranges
thanks for the help
Old May 20, 2012 | 02:01 PM
TMW's Avatar
TMW
The cheapest way is to put a leveling spacer on the strut assembly. It's about 1inch thick and bolts to the top of the strut (your coil over shock assembly). They usully sell for $100 or less for two. They do restrict your up travel and can over extend your down travel compared to stock and if you do a lot of off roading you may notice it. I have used them on my 04 Tacoma without any problem. The better way is to replace your front shocks with Bilstein 5100 shocks. They have a clip you can set for different heights up to 2.5 inches. The shocks run about $80 each maybe a little more. The 5100 does not restrict your up or down travel.
Old May 21, 2012 | 10:38 PM
bowtie4j's Avatar
check out hell bent steel they make a good and cheep spacer. how much space between the tire and fender? check them front and back and the difference is what size you need!
Christopher Clark
Dec 24, 2013 02:25 PM
d2_127
Jun 3, 2010 10:41 PM
moose
10
Mar 1, 2008 09:26 AM
garyj
Jun 25, 2007 07:29 PM
