Sponsored by:
Sponsored by: Kumho
89 F-150 won't start. No power to injectors
Old Oct 9, 2006 | 11:04 PM
ChurchBuilder's Avatar
Default 89 F-150 won't start. No power to injectors
I have an '89 F-150 with a 5.8L. I sat for a year or so and won't start. There is power to the fuel pump (40lbs pressure) and spark. It will fire with starter fluid but won't start. I don't think the injectors are working. Thjere doesn't seem to be any fuel getting into the cylinders. (plugs smell like started fluid but never gas) I drained the gas out of the tank and added new but still not starting.
Someone suggested buying a new computer. I will but I'd like to try another solution before sinking $100.00 dollars with no real proof that it's the computer.
Any suggestions?
Old Oct 9, 2006 | 11:51 PM
Justardnck's Avatar
Default RE: 89 F-150 won't start. No power to injectors
ORIGINAL: ChurchBuilder
Any suggestions?
89 has multi port FI correct? If fuel makes it to the schreder valve where you checked the fuel psi that tells me that either the injectors aren't firing (possible fuse... yes there is an injector fuse). I wouldn't blame the comp just yet
Old Mar 11, 2009 | 12:55 PM
Rome's Avatar
Default No Power to Injector - 1985 F150
I have the same problem with an '85 F150 302V8 FI. Could you let me know where the fuel injector fuse is located in the engine?
Old Jun 7, 2009 | 01:56 AM
AeSix's Avatar
Most autoparts stores will help you out with locating where the part goes. The guys down town here will pull out a Haynes manual and show ya. Part of that is the potential sale of the manual, but it's still a nice gesture regardless. If it takes buying a set of fuses (which it might not even be a normal/buss fuse anyways), then I think it's worth it.
TrueBlue72
Feb 16, 2012 07:08 AM
Gloveberg
Dec 21, 2010 09:35 AM
alexhasatruck
Nov 20, 2007 06:35 PM
superddd
Jul 28, 2007 12:10 AM
Roadking666
Aug 19, 2006 01:14 PM
